Help — third rear brake light
Old Jul 4, 2018 | 02:09 AM
abqhudson's Avatar
2014 e350
Brake light works fine. But, the sensor that lights up the dash to indicate a bulb failure comes on intermittently. About to sell the car.
I'm going to try to clean the connector contacts tomorrow. Does anyone else have any help/advice for me?
Thanks..
Old Jul 4, 2018 | 11:18 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Mine was doing this, so I removed the light from the trunk and took (i.e. cut) the lens off. I was expecting to find bad solders, broken wiring, or corrosion, but it was all just fine. I use silicon sealant to reattach the lens, then reinstalled the light, being careful not to over-tighten the nuts - they only need to tighten enough to stay in place. After that, no more errors. All I can figure is that the light was bolted too tightly in place and caused an intermittent short.
Old Jul 5, 2018 | 10:27 AM
abqhudson's Avatar
2014 e350
Cleaned the contacts - put it back together being careful not to over-tighten.
Wish me luck.
