2009 CLK 550 cab- how to change HID low beam?
I've looked online and could not find a video (or instructions) for my specific year/model.
The vids I did find show different setups than what I've got -- the most common showed 2 clips that could be pinched and removed to then remove the whole bulb and attached unit.
Any help is MUCH appreciated.
Here's what mine looks like- the clip looks easy enough to remove but then what...
Reinstall reverse order.
I recommended replacing OEM D1S to the Osram 7000K Cool Blue Boost. Crisp LED white like the newer Benzes. I have them on both my AMGs and LOVE
Have fun!
UPDATE:
Turns out that I have no retaining clip.
After disconnecting the battery, I unclipped the power cable on the ballast and then rotated the whole unit counterclockwise a little bit / gently.
I could feel it disengage and from there it just slid backwards / out.
Thanks again. Much appreciated!
