P2422 - Evap Purge Valve Stuck Closed
I replaced the original purge valve on the charcoal canister with another identical one from a clk55, cleared codes, waited for a few days, and the code P2422 came back again. Im 99% sure that the purge valve from the clk55 worked before i removed it. Could this be a problem with the charcoal canister? I did not replace that, as the bracket from the clk550 and the clk55 are not the same.
Is this part a valve or an air pump? Can I take it apart and clean it? It looks possible, but I dont want to mess it up before asking.
If the charcoal canister is plugged, would I just be able to remove the valve from the canister and would it pass codes that way?
The reason I left it uninstalled, is the plastic cover did not look like it had any type of pass-thru to the tank. It was just a solid piece. I'll have to take the back seat off and see what I missed. That must be it tho.
Thanks again!
T into the line here to pull fuel pressure from the tank?
Freeze the Frame @ 2:02 for a decent picture of what Im going to try to accomplish.
