Turning signal DRL LED
Hey, I am going to start the turning signal DRL project on my CLK, I am trying to achieve something similar to
Now the first problem that I encountered is the white turning signal socket that is attaching to the headlight as all the wire harness is hidden inside the headlight. I am wondering how can I attach the DRL module and the resistors to that socket or is there an adaptor for that ?
you will have to remove the headlight to get to the wires . you can actually do it without but its a pain in the neck . Once you remove the headlight . Remove the harness plug from thats inside the headlight . You need 2 very small flathead screws and you have all the wires there . You can then just solder to it . Personally i don't think it would look good . but its up to you
