Which rotors to use?
I need to change my rotors both fronts for my 2007 clk550 coupe, 123k miles.
Which ones would you advise? (See links below). Also maybe are there cheaper one (would like to have drilled or dimpled), anyone?
https://www.fcpeuro.com/products/mer...210912#fitment
or
https://brakeperformance.com/brake-rotors/cross-drilled-brake-rotors-black-zinc-coating.php?d=59840&gclid=EAIaIQobChMIz7bYg4Gg3gIV h9lkCh3eLAekEAQYAiABEgI1hfD_BwE
Or these guys :
https://brakeperformance.com/brake-rotors/premium-dimpled-&-slotted-brake-rotors-black-zinc-coating.php
Personally I would not be too concerned about "cheaper" ones. Just shop for the best price on the ones you decide on. But you could get none drilled ones for a few dollars less. Once again, I would not.
After all rotors isn't something to neglect. How do generic brands justify low cost rotors? Lower quality for the metal? Or the process maybe...
Rodney, would you say same goes for shocks/struts? Genuine vs for eg. Bilstein?
I have a mechanic who says he's got the original so should I go for it?
For the rotors, it seems that genuine is going to cost me though.. but after inspection, the 'lip' at the edge is not even a mm out. I think the thickness of the rotors in the inside, have to be 28mm btw.
Interesting btw, I found that the other side of the rotor (the side facing under the car) is thinner than the one facing out (wheels bolts side).
I'll make some research to find oe rotors. Would you also change rotors bolts? Is there a torque spec on these btw?
Thanks guys.
I just ordered new rotors from R1Concepts.com -
https://www.r1concepts.com/eline
I went with the Eline drilled and slotted rotors as
I am an old man and don't drive as fast and hard
as most of you do -
I wanted the drilled and slotted rotors for looks -
For hard driving R1 offers these:
https://www.r1concepts.com/geomet
I worked with Kevin at R1 and he gave me the
best price shipped by far compared to the other
brake / rotor companies I spoke with -
Kevin@r1concepts.com
He addressed all my concerns and while I have
had issues in the past with other companies rotors...
Kevin did not have any negative comments about
other companies - he just sold me on R1 -
I ordered on Tuesday and the rotors are slated to
be delivered tomorrow which is Friday - FAST -
Thank-You
D.B.
