Can’t set time
This could be a wiring issue or a bad COMAND unit. The signaling that has the radio powering on and off with the ignition is via the CAN bus. If there is a problem with that wiring, it will not get those signals. Are you going to DIY this? If so, remove the radio and check the CAN bus wires - the brown pair C1 and C2:
http://benzbits.com/Audio10PinOuts.pdf
The iPod interface connects to the back of the COMAND unit. Basically, the vehicle wiring harness is unplugged, then plugged into the iPod harness, then the iPod harness plugs into the COMAND. It's "inserted" into the wiring harness that way. The iPod interface uses the power, AUX in, and CAN bus wiring, but nothing else. The iPod interface does not use the fiber optics, so it has to be plugged directly into the COMAND so as not to be bypassed. This explains the wiring:
http://benzbits.com/IpodWiring.pdf
What I would do is remove the iPod interface wiring from COMAND, reconnect the fiber, and see if that fixes it. if so, then the fault is in the iPod module. If not, then the COMAND unit was damamged by the short.
