722.6 Transmission Jerks With Gear Shift After Warming Up
I thought by replacing the leaking pilot bushing that it's what was causing the hard shifting, but it did not fix it.
Here's what it is doing. The 722.6 shifts fine on cold start ups if I start driving immediately. BUT that only has lasted for about 2-3 minutes. Then it starts bucking and shifting too early -- even going to 5th gear at 35mph bogging down the engine.
I'm guessing after it has a little warmth in fluid it is causing a problem in the computer system?
Could this be the conductor plate causing the problem?
When it shifts hard it bucks and acts like when someone dumps the clutch on a 5 speed at a very low rpm making the vehicle jerk. Even slowing down coming to a stop it sounds like it is not operating the torque converter correctly and it feels like it's stuck in a higher gear as you can hear the engine grunting at 900rpm nearing the stop. Hope this makes sense to someone who can suggest what it is to fix it?
Any ideas? This car is a 2004 CLK320 Convertible model with only 78,000 miles on it.
Thank you.
Hope a flush will fix it -- and not end up being the conductor plate. Someone suggested to also look for antifreeze in the transmission fluid (Hope that's not happening either).
5G Transmission
Below are the WIS docs for the pan-drop filter change and the flush. To do this properly, you'll need to have at least 16 quarts of fresh fluid: 4 to refill after dropping the pan to change the filter, and 12 for the flush procedure. If you;re really OCD, change the filter AGAIN after the flush.
http://benzbits.com/722_6/FluidFilterChange.pdf
http://benzbits.com/722_6/LevelCheck.pdf
http://benzbits.com/722_6/TransmissionFlush.pdf
