SRS 9243 code
SRS 9243 code
I have a SRS light and when scanned it comes up with code 9243 "The resistance value in the ignition circuit containing component front passenger side airbag ignition squib is too high".
However when reading the data stream it says my passenger side airbag is "OK. I am getting these readings though:
"Resistance of ignition circuit with component r12/13 (drivers side airbag ignition squib 1) - Resistance too large
"Resistance of ignition circuit with component r12/14 (Drivers airbag ignition squib 2) - Resistance too large."
So the error code seems to suggest the passenger side but everything reads "OK" when I read the data except the two that are listed above.
I have taken the connectors off from both side airbags and cleaned them. I have also traced the wiring and checks for kinks.
Which side do I focus on? What should I even be looking for?
