Can't determine which P/N for non AMG fog lights
I've got to replace both fogs on my 04 CLK with a non-AMG bumper.
It is this bumper specifically:
Are these the correct part numbers? 1698201556, 1698201656
They're shared across so many cars and I keep running into other fogs that say fit but don't look like the right shape at all. I think they're from the previous generation CLK and are listed incorrectly.
If you could provide your VIN it would be much easier to help you
Those part numbers are definitely incorrect. Probably! correct part numbers are 2038202756, 2038202856 or 2038201156, 2038201256
Changed my mind, won't guess without VIN :-D
The VIN wouldn't be helpful in this case. The car had the AMG bumper but now has a non AMG bumper. The bumper part number is A2098850025.
2038202756, 2038202856 or 2038201156, 2038201256 I think are correct. After doing a little picture research it looks like even though the fog light holes are ovals in this bumper the fog lights themselves are not and just sit behind the bumper. It is the bumper that gives the "D" shaped lights the oval look in the end.
Usually Rodney says that, but .... :-D
"Please take a moment to visit the User Control Panel and update your profile to include your car model and year, and your location (at least country). This information will then appear below your name and avatar on the left side panel next to each post you make. This will greatly help others to give you better information. If you are using the mobile version of the site, you will need to switch to the "full" version to get to the User Control Panel. " ©
Based of a photo (a hope it's your car on the photo) you attached you have Bi-xenon lights, in this case probably! you should choose 2038202756 and 2038202856 (they are marked as fog lights for cars with Bi-xenon).
Rudeney (03-28-2019)
