Crankcase Pulley issue
I replaced the pulley but the new one has the same exact wobble. Brand new bolt and everything was torqued using the m113 specific pulley tool. The pulley is made by Febi/Belstein and I've had zero issues with their parts before.
Before returning this and blowing even more money on an OEM replacement what else should I check? So far I've also replaced the front crankshaft seal and idler pulley because it was noisey. I carefully checked if there are any marks on the engine block or upper oil pan, nothing. Not even a scratch.
Engine vibration is more noticeable with belt installed. It's super smooth even with the wobbly new harmonic balancer in place when belt s off.
Should've done more research.. lesson learned. Wouldn't have cared so much if it didn't involve spending money on a specialty tool and having to take out and re-install the cooling fan and a number of other things.
