Idle rough
I am no mechanic. Any thoughts?
My mechanic would tell you (over the phone) that it could be any one of 200 things (or however many possible engine codes there are).
Good luck- hopefully it's nothing too catastrophic!
It would be cool if you can provide an update in case anyone else has a similar issue down the line.
1. Make sure everything in the car is turned off and closed.
2. Turn the key to position 2 so all the dash lights are illuminated.
3. Press the accelerator fully to the floor, depressing the "kick-down" button.
4. Hold he pedal for 5 seconds and continue to hold it down.
5. Turn the ignition switch back one click to position 1.
6. Release the accelerator pedal, but leave the key in position 1.
7. Sit quietly and wait for about two minutes - do NOT open or turn anything on.
8. Listen for a "click" or "ping" noise form the dash.
9. Start the engine and drive the car for at least five minutes.
Luckily I cut it off quick before any damage was inflicted on the flywheel, so once the starter was refurbished, the engine fired up on the first crank, and proceeded to purr like a kitten, smooth as silk. This is got to be one of the most unusual causes of a rough idle that I have ever encountered in any vehicle.
Any more ideas with the added information?
