CLK 220 CDI ENGINE
I purchased CLK 220 CDI BVA 5,722,699 OEM 646,966, 230,000Km to the counter RHD Steering wheel right.
A few months after the acquisition (July 2018), I had the start-up report, the starter was latching but the engine did not happen, three months after the replacement of the starter, I had the same problem. I replaced the starter but the mechanic told me that there were three steps to go. Before the replacement the car wheel has changed very well, so I changed the crown I have a shot down regime between 1000 and 2000. I have never lost power and as soon as I climb in the towers I have more jerks.
I connected the OBDII Bluetooth, I have the following error codes:
- P0336: Crankshaft sensor A - performance / limit problem.
- P304C: Description not available
- P2134: Accelerator pedal position sensor / contactor F
- intermittent circuit - P2632: Fuel pump B - open circuit
- C025A: Description not available
- P3230: Description not available
- P3538: Description not available
- P3035: Description not available
- P0000: No fault detected
This is the code P0336 crankshaft sensor that has just appeared following the replacement of the crown.
