Balance Shaft VIN Lookup?
MBworld Guru
Go here and plug in your VIN to get your data card with the engine serial number:
www.datamb.com
This explains the range of engine serial numbers affects:
http://benzbits.com/BalanceShaftTSB.pdf
Scenario 1 is the dreaded balance shaft failure. The others are simple changes of the camshaft adjuster solenoids (a.k.a. magnets) and seals.
www.datamb.com
BALANCE SHAFT ISSUE CLK 550
