AC Leak...Line or Compressor? 04 CLK500
Old Jul 22, 2019 | 04:00 PM
OCLK500's Avatar
2004 CLK500
I have some kind of leak that's preventing my AC from blowing cold. It blows just fine, but only ambient air. It suddenly stopped blowing cold so I purchased a recharge kit to try that out. After charging the system, I turned on the car let the engine run with AC on coldest setting at full blast. It didn't get any colder so I turned the car off. After turning the car off, I immediately heard a hissing sound coming from the the area near where the compressor sits.
I want to know if this sounds more like a cracked or damaged AC line or something wrong with the compressor. I can see some florescent green liquid that puddled on the under tray. From what I gather, this is the AC refrigerant. Being that I hear a hissing, I'm hoping it's something more simple like a cracked line rather than a compressor that needs to be replaced. Any help or insight would be greatly appreciated!
Old Jul 22, 2019 | 04:06 PM
Agent-A01's Avatar
05 W211 E500, 03 C215 CL55 AMG
Might be easier to just take it to an AC shop.
They will be much quicker at diagnosing your leak.
Old Jul 23, 2019 | 01:01 PM
irokdastar's Avatar
2004 CLK 500
I had the same issue turned out to be the o rings on the line going to the compressor . You can test this by going to your mechanic and put it on a machine or buying the dye kit that lets you see where the leak is coming from . I would check the O rings . Whatever it turns out to be you still need a shop to draw out the old refrigerant and air in the line before refilling it .
Old Jul 23, 2019 | 01:24 PM
ygmn's Avatar
2015 E400 Sedan
GO to AC mechanic... as they have proper equipment to service.
Vacuum pump Evac machine gages etc..
Old Jul 24, 2019 | 03:20 PM
0zranvest's Avatar
2007 clk550, 2006 clk500 (sold)
Find a Mercedes indie to check the vehicle. I had 2 AC issues with 2 different vehicles. 07 clk550 had A/C o-rings replaced in 2011 under warranty .
I had a SAAB with a bad AC. I took car to shop specializing in European cars, but they misdiagnosed the leak. They changed schrader valves, o-rings, some piping, and eventually said I needed replacement condenser. Luckily for me the shop required 4 days to get the condenser. While waiting I ck'd saab board & found a nearby SAAB indie. He put car up on the lift & tore away the AC tubing insulation which revealed a leaky connection. $200 fix & all was well. Good luck
Old Jun 29, 2021 | 11:06 AM
BasharHalabi96's Avatar
2012 cls 550
I dont have a leak at all.
the ac machine extracted 590 grams of r134a which indicates no leak at all.
Old Jun 29, 2021 | 11:10 AM
2012 cls 550
Update
Today i took it to another shop that diagnosed my problem as a clogged ac condenser.
he told me that i have to buy a new one and then have the new compressor checked and put new oil in it and the check the system lines.
what i am sure of is that i have no leaks in my system and my original ac coil is stuck in closed position
i will keep you updated
