W209 CLK 240 Fuel Smell
Old Sep 7, 2019 | 10:16 AM
GrantRob's Avatar
CLK 240
Shortly after starting the engine, there seem to be a smell of fuel both outside and inside the cabin. No obvious signs of leaks under the car or in the engine compartment. Anyone suggest where to start troubleshooting?
Old Sep 8, 2019 | 07:28 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It might be burning oil. Leaking valve cover gaskets that drip onto the exhaust manifold (especially the right side) are common. If not, check the fuel line from the frame to the fuel rail, and also check the fule pump and sender units located under the rear seats.
