wiper arm removal
wiper arm removal
Trying to get my wiper arms removed and it seems the link has gone dead for the instructions posted before.
I've got the cap and nut offs. I presume I need to use a wiper arm puller to get the arms off the bolts because they ain't moving.
Do the wiper arms need to be in a specific position to be removed? Anybody have a recommended puller for w209?
Thanks,
Z
Thanks,
Z
No puller required. What is required - WD40 or similar penetrant sprayed on the wiper shafts. Couple minutes and you can wiggle the wiper arm easily. Did this procedure on 3 vehicles today (one w209 and two w203, which has the same wiper arms )
z0lt3c (09-21-2019)
Well I let the wiper arm bolt soak in PB spray for days and still had no luck getting it removed. I went down to autozone and rented a tie rod end puller (see: https://www.autozone.com/loan-a-tool...rod-end-puller) and it popped the wiper arm off no problem. So although it isn't technically required, it made the job much easier.
