AutoTalent | Renntech Ecu + Wing + Brake For Mercedes-benz C209 Clk350 2004-2010
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's! Our experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability. RennTech tuning software for Mercedes offers significant gains in horsepower and torque across the vehicles entire power band. By modifying ignition timing and throttle mapping, optimizing air/ fuel ratios, increasing the engines rev limiter and modifying boost mapping for turbo charged vehicles, RennTech performance software unleashes your Mercedes true potential.
Features
Gains up to +22HP & 20TQ
Long-lasting and driver reliability
Significant gains in horsepower
Increases the performance
Significant gains torque
Increasing the engine's rev limiter
Incredible performance gains
Stock Performance
268 HP @ 6000 RPM; 258 LB-FT @ 2400-5000 RPM
Modified Performance
290 HP @ 6000 RPM; 278 LB-FT @ 2400-5000 RPM
Renntech Carbon Rear Mount Dtm Style Wing
Click HERE to order Dtm Style Wing!
RennTech full carbon fiber Aerodynamic parts for the C209 CLK is the proverbial “cherry on top” and a stunning addition to the rear of the CLK exterior. Its unique design complements the refined trunk lines yet offers a more aggressive, stand-out look. RennTech Offering aggressive styling and functional performance; our fully adjustable DTM style rear wing is designed to work in conjunction with our carbon fiber rear deck lid spoiler and improves rear down force and stability at higher speeds. The rear wing mounting piece and uprights are a single piece, manufactured from T-6061 aircraft grade aluminum and our full carbon fiber wing element includes adjustable struts as well as machined aluminum end plates with the RennTech logo. The rear wing mounting plate with wing uprights attaches to the trunk lid via the included trunk reinforcement mounting plate. This allows the wing to bolt behind the license plate and can easily be removed or installed within 10 minutes.
Features
High quality prepreg carbon fiber finished
Offers a more aggressive, stand-out look
Durability and stunning good looks
Produces greater down force
Easily be removed
Installed within 10 minutes
Perfect design
Renntech Performance Brake Package
Click HERE to order Performance Brake Package!
Click HERE to order Performance Rear Brake Package!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
Deliver more consistent brake pedal feel
Improves vehicles responsiveness
Reduce fade compared to stock
High-performance brake pads
High quality material used
Improved performance
Long-lasting reliability
Braided steel lines
Renntech Performance Transmission Upgrade
Click HERE to order Transmission Upgrade!
RennTech transmission upgrade consists of a complete transmission disassembly and inspection as well as a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings as well as a new transmission pan filter. RennTech 722.9 Five speed Mercedes Transmissions increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. RennTech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. Our upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Increased engine performance
Improved shift response
Greater drivability
Shift timing
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
