CLK 200K - Slight hesitation @2000rpm
1 Post
W205 C180 BlueTec
Hi there, friends. I have an issue on my CLK 200K, when cold. It's a very simple thing, but annoying.
The car has automatic transmission. I put on D, (S mode) and start driving. When the RPM are reaching more or less 2000rpm there are a slight rpm drop (+/-100rpm), but without gear change. Like a little loss of power. After that the rpm rises again normally with gear change, etc.
Try to read codes and only had one pending (P0172 System Too Rich Bank 1).
Any ideas about what might be the issue? When warm everything is fine, no slight rpm drop.
Thank you.
Thank you.
Can't help you Duda, as my 2008 CLK350 does bog down around 2K RPM in second gear before recovering, but doesn't have any codes nor any issues with cold.... almost feels like you have an injector issue or a fuel mix problem, but no ideas on how to help you with that one... Sorry!
1 Post
W205 C180 BlueTec
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
