HELP!!! - CLK320 Headlight Problem
Old Jul 20, 2004 | 06:05 PM
KJ-TypeR's Avatar
M3
Hi,
I got a CLK320 who's Xenon headlight always goes out. The headlight is fine because it will magically start working again, but later it will go out again.
Has anyone else experienced this problem, and if so, how was the dealer able to fix it? My dealer has replaced the Xenon bulb 5 times, but the problem still persists. I told them it was probably a wiring problem (since it works intermittently), but they won't listen to me.
Any thoughts or suggestions would be really appreciated!
Thanks,
KJ
Old Jul 20, 2004 | 07:34 PM
Frisco's Avatar
03 CLK500, 04 X3, No 07 GT3RS :(
I have had the same exact problem, with the dealer repeatedly switching out the bulb and producing the same outcome.
Old Jul 20, 2004 | 07:58 PM
Shine_1023's Avatar
FX35 plus
I got the same issue when I swap the 12000K HID bulbs
(for show only)
poor connection on the bulbs random shut them down.
Solution....change another set of HID bulbs (6000k)
they work fine so far.
Old Jul 20, 2004 | 08:43 PM
KJ-TypeR's Avatar
M3
(for show only)
The problem is, it's the stock HID bulbs that are giving us the problem. And the dealer is switching them out and we still have the problem afterwards!
Someone help us!!!
- KJ
Old Jul 21, 2004 | 05:17 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Someone help us!!!
- KJ
Well, even if I give you a suggestion, it seems the dealer won't listen to you. So what good would it do?
(It's probably the ballast, possibly the igniter but since the light goes out after working, I would say the ballast. Wiring problem would cause the issue too, but generally doesn't go bad by itself.)
-s-
Old Jul 21, 2004 | 09:16 AM
Chip's Avatar
08 E320 Bluetec
Lemon Law. Mercedes has got to deal with problems like this. There have been too many times with all models and dealerships with things that can't be fixed. Laying out 50-60k for a car that you can't drive at night is unacceptable.
Old Jul 21, 2004 | 04:13 PM
KJ-TypeR's Avatar
M3
-s-
Thanks for the advice man, I'll tell them to change the ballast and igniter next time I go in.
- KJ
Old Mar 29, 2010 | 10:46 PM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
bump, anyone else have this problem? my driver side just went out! no low beam or parking light. turn signal work and so does high beam, already switch out the bulbs and still nothing, not getting power.
Old Mar 29, 2010 | 11:02 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Check the fuse too !!!!!!!
Old Mar 30, 2010 | 12:47 AM
AzCamel's Avatar
did that, fuse 62 and 63. nothing.
Old Mar 30, 2010 | 01:01 AM
idouoooo's Avatar
2005 CLK500 Cabriolet 2004 Maserati GT Coupe 2004 BMW 328cic
Guys if the bulb burns out it WILL NOT COME BACK TO LIFE. So if the light is going out and coming back on it is NOT the Xenon bulb. Light bulbs do not work like that (even Xenon bulbs). With Xenon headlights when you get flickering or bulb going off and on it is the ballast or igniter that’s the problem. Actually when igniters burn out they don’t come back on. I would say 99% of the problem is the ballast. Most likely moister is getting to the interior of the ballast. The other 1% is loose connection to the headlight (which is very unlikely as Mercedes harness connections are very sturdy).
Check the ballast, if under warranty demand Mercedes to change it. If not look on eBay or hidplanet.com/forums as you can find the ballasts for $50-$100 there.
Old Mar 30, 2010 | 01:13 AM
dumpsta's Avatar
SLK280(Gone), C63, CLK550
No. Just before Xenon bulbs die they change colour (pink), and always flicker/blink a bit for a few days before it actually goes out.
But since the OP replaced the bulb 5 times, then it is not the bulbs.
Old Mar 30, 2010 | 01:15 AM
AzCamel's Avatar
well fuse when i unplug fuse 63 it turns off the passenger side lights, fuse 62 does nothing. so it seems its not getting any power at all, i went through all the fuses and they all look great. The thing that got me is that its just not the HID low beam but the parking light is not coming on either on the driver side. are they connected in the same wiring/fuse?
Old Mar 31, 2010 | 01:26 AM
AzCamel's Avatar
Old Apr 1, 2010 | 06:31 PM
AzCamel's Avatar
So i figure it out.
something weird is that the peanut light in the high beam housing area is attached to your HID ballast, so if that goes out so does your peanut light, so if you ever wonder if your ballst is done then a good reference is the peanut light. Another thing is if you want to get to the ignitor you must open up the housing.
All in all it took me about 2hrs from start to finish, that is with removing the headlights, the housing, replacing both the ballast and ignitor, and putting everything back. I do not think my ignitor is bad but replaced it anyways
Old Apr 1, 2010 | 10:55 PM
rosswell's Avatar
S320 GL350
Good job and pics. I had a bulb flickering and flashing and going out intermittently - the dealer replaced it with a new xenon bulb (the previous bulb was a blue-colored aftermarket one) - and I've had no problems since. Now I need to go buy another to match on the other side since the color is white on the new one - bluish on the other side.
Old Apr 2, 2010 | 11:08 PM
rosswell's Avatar
S320 GL350
Is there a way to align the height???
Want to raise my beam a couple inches on the driver's side - are there alignment screws behind the housing???
Old Apr 3, 2010 | 01:36 AM
Klinh's Avatar
Search for my posts.
Old Apr 3, 2010 | 11:35 AM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
So i figure it out.
What's all this carbon fiber in these pictures?
Old Apr 7, 2010 | 03:41 AM
AzCamel's Avatar
the carbon bits are from my supra, the HID ballast and ignitor was resting on my Carbon Fiber radiator diverter.
Old Jan 24, 2015 | 02:24 PM
Jimbo Bigbelly's Avatar
ML500
KJ: A dealer that switches bulbs he charges 200 for without having the test equipment to validate the old bulb is faulty is a dealer you should report to the BBB, yelp him, and make sure he feels the wrath of the internet. There are only a couple of HID bulbs currently in use by Mercedes. A test fixture with a battery, an Igniter Control Module (this is Mercedes-speak), and an igniter (again Mercedes-speak) for both bulb types is easily done. Phillips is the OEM for Mercedes HID bulbs and you can get a pair of Phillips D2S bulbs from Amazon for $79, and my Igniter Control Module from Mercedes was 750, but Hella made the OEM part (got the Hella logo on it) for Mercedes, and again Amazon had the Hella for $199. To clarify Mercedes-speak, the Igniter Control Module is the silver metal box that on my ML is mounted under the plastic headlamp module, the Igniter is the block mounted at the back of the HID bulb. In many posts, people call this the "ballast" and the metal box the "igniter" but if you order and "igniter" from Mercedes, you will get the little block at the back of the HID bulb.
