CLK w209 200K misfiring
Clk 200 k w209
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Hey guys i have a w209 clk 200k, which has recently started to randomly misfire, at the start it was a slight vibration that i could feel when the car was steady. I took the car to a mechanic and he disconnected the MAF wire and the vibration stopped i then purchased an after market one and had it replaced but the misfiring got worse, another mechanic suggested that it might be the spark plug and injection coil packs, so i had these changed to but every time i clear the codes they come back. With P0301,2, 3 and P0171. I checked the vacuum lines around the valve cover but can see any thing wrong with them. any suggestions to what might be the problem as i cant be asked to go to another mechanic and pay for something thats not causing the problem.
My path of pursuit would be things associated with the P0171 and looking at what would affect the entire bank. I would recheck the vacuum lines and my next focus would be the O2 sensor. I have no idea how to check the O2 sensor, but you could do a search on the forum or the web in general.
Does anyone know or have a layout diagram for the vacuum lines for the clk200 w209?
I have one which is just hanging around.
Btw, I had a similar issue, it could be your MAF sensor... Buying a cheap knock off can cause the problem, you better off buying a used one from another clk on ebay, just match the part number.
Also check the egr solenoid lines, they are under the engine cover.
