Command not turning on after battery change and disconnecting fuses
So my battery ran out and I tought I have a parasitic drain. I disconnected all fuses and started to put them back one by one. OK, I found the drain but now I have two problems :
Windows don't go up after you open the doors they stay open a bit and I manually need to raise them. I read something about "you need to reset the windows?"
Secondly - command just starts for 10sec with the MB logo and turns off.
What can be wrong here? I tried disconnecting the command fuse, the phone fuses and basically other fuses also.. I added also a new battery..
What might be causing these issues?
It's clk w209.
