Quick question. I found a 19 or 20 inch rim that has a lug pattern of 20x9 5x114.3 +35 offset and 19x9 +35 / 5x114.3. Would i be able to put an adapter on these rims to fit?
Your first question may be : Why dont you just find a rim thats 5x112? Well this rim only comes in that pattern by the supplier. ive tried looking for it through this persons site but its not available.
do you even google bro. I would post a link but the top almost the entire first page is what you are looking for
2009 CLK350 Cabriolet with 18" AMG Fitment TSW Rims
If you want your wheels to be RIGHT, stay away from adapters. These cars are very finicky where even bore spacers will give you problems. Any mis-location of the wheel will generate a runout condition which can only be balanced at one speed.
I'm running TSW 18's on mine with bore spacers and have found the ONLY way to repeatably mount the rim on the hub is with aluminum spacers glued in the bore with Loctite.
