P2767 code on 722.9 Transmission
We have been having trouble with the transmission lately. I noticed sometimes I am unable to accelerate past 30 to 40 miles. The trans does not shift. From what I researched I believe this is called limp mode. This did not happen all the time but lately it is happening every time. Also when I tried to go in reverse, it was as if it was in neutral, it would not move. I put it to park and back to reverse, and that worked.
I used an OBD II scanner and got the error code P2767: Transmission speed sensor / turbine shaft speed sensor B - no signal
I did a bit of research but I am still not 100% on what needs to happen. From what I have read/seen it is the conductor plate on the valve body that needs to be replaced, rarely the solenoids. What I am confused about is the speed sensor sits on the conductor plate, so I am wondering if that is the only thing that needs replacement since that's what the error code was
If anyone has any knowledge/experience of this and can give me better insight, I would appreciate it. Also if there is additional info needed, let me know. Thanks
The dealer would replace the plate and program on site but its $1700+
Another complication would be which plate/valve body your car has. There are three versions of the plates on the 722.9 (VGS1, VGS2, VGS3). VGS1 is not repairable and requires the plate + valve body to be replaced. VGS2 & 3 can be repaired and dont need the valve body replaced.
PM me your VIN and I will check.
(PM sent BTW, thanks!)
You're looking at around $200 plus shipping and fluid if you remove the plate yourself, send it off to be repaired, then reinstall. I would not reccommend DIY replacement of the sensors if you arent very mechanically inclined.
Repair options outside of the dealer include finding someone who can get new parts and SCN code them for less than what the dealer charges. Or, you can get the speed sensors replaced. Besides the fact that replacing just the sensors requires some good skills in soldering to Mylar ribbon cable, it also might not be a proper fix. In some cases, the speed sensors themselves are just fine, but the plastic conductor plate warps so that they are not close enough to the rotating gears in the transmission to pickup a signal.
