What is this sound?! Please see the video.
Old Mar 8, 2020 | 07:54 PM
Sabadara's Avatar
2007 CLK550
Exclamation What is this sound?! Please see the video.
It seems to be coming from the throttle body but I'm not sure. It has the same sound with the engine cover on. The car has a rough idle, the RPM needle drops and jumps back up. Sometimes it even stalls. I have cleaned the MAF sensor and the throttle body but nothing changed. The air pump seems to be working fine. Could it be a faulty MAF sensor, a vacuum leak, or an old fuel filter/pump? If not, what else could it be, and how can I diagnose and repair it?
Old Mar 9, 2020 | 03:07 PM
dhurley's Avatar
GL320
Check your intake flap actuators and make sure no part of the linkage is broken.
Old Mar 10, 2020 | 12:34 AM
irokdastar's Avatar
2004 CLK 500
I just had the same issue turned out to be I had 2 bad coils . Get a good scan tool and look at the live data . Look for a coil thats misfiring. Your looking for the cylinders that looses spark for a second . I had no check engine light on mine but when I pulled up the live data you can see 2 cylinders misfiring for a split second but it wasn't enough to throw a code .
Old Mar 11, 2020 | 04:07 PM
Sabadara's Avatar
2007 CLK550
Thanks for the reply. I did have a check engine light and the scan tool showed three codes: coil C, coil G, and misfire in cylinder 7. I replaced those two coils and the car seems to be idling smoother, but this problem still did not go away. What kind of scan tool could I get to look at that live data? I don't wanna throw the money on 6 other coils just to find that the problem is still there.
Old Mar 13, 2020 | 04:15 PM
irokdastar's Avatar
2004 CLK 500
Scan soft MBII is the best for Mercedes for around $150 . Get it used and save money . Can you do this . tun the engine open the hood and take off the small front engine cover . take a long screw driver and look for plastic flap actuator on the intake . if you put the screw straight down you should be able to open the actuator . see if it goes away . If it does its the actuator inside the intake and you will need a new intake . Be careful as the engine is on . The next thing to check is the valve body . Turn on the engine and remove the engine cover and MAF . Take a mirror and look at the valve body while idling . If its moving on its own and is causing the flapping Then your valve body and or motor is going bad. You will need a new valve body . If you have a horoscope camera it will be even better . Do this before buying the scanner .
