Car needs a boost every few days . Need help
If so, check the level. If water is needed, make sure you use DISTILLED WATER.
I think most people don't even think about battery maintenance, perhaps I'm wrong. I check my battery water level about 5x/year.
Under no circumstances should you ever put tap water into your battery.
https://www.consumerreports.org/prod...6436/overview/
https://www.ebay.com/itm/Lot-2-Car-B...sAAOSwmcJdl-fR
I have one of these on each vehicle I use, and simply turning the dial reconnects power whenever I need to drive the vehicle after a long period of dormancy.
If you prefer not to disconnect the car's electrical power, one of these trickle chargers can be connected to the battery in the car, so that the battery never runs down as long as the trickle charger is plugged in.
https://www.ebay.com/itm/Car-Battery...wAAOSw0w9d3OG0
The above two temporary fixes will ensure your car fires right up whenever you need to drive it after a period of hibernation, until you are ready to have the wiring scrutinized.
