Car won't start when warm outside or warm engine
I have CLK 220 CDI 2009 that doesn't want to start when it's warm outside, about 15 C degrees or when I drive it enough for the engine to warm up to regular temperature.
When I have the issue this happens:
- I turn the key to position 2
- all dashboard lights appear as normal except for the coiled shaped one (diesel prewam light ?), which doesn't appear at all
- the displays shows "Run flat indicator inoperative" message
- after a 4-5 seconds, the engine fan starts running at full power
- when I try to turn the key further, nothing happens, engine doesn't crank
If the engine cools down and it's less than 14-15 C degrees outside, the car starts normally.
I scanned the error codes with an iCarsoft MB v2.0 with the engine on, just after I started it and again when it doesn't start (with the key on).
I used the auto scan feature.
On the second scan the scanner is not seeing the ECM module anymore.
I did the following:
- start the car
- auto scan, scanner shows 17 modules
- record all error codes, except for the ECM, TCM and ESM. I delete the errors for these before recording them, like an idiot.
- delete all error codes
- driver the car for 20 min to warm engine
- stop car
- try to start car, it does want to start with symptoms describe above
- auto scan with key on, scanner shows 16 modules (ECM missing)
Do you think there is anything that an amateur like me can try to determine the cause of this or fix it ?
And does anyone know a Mercedes specialist around north east London that works in this period ?
These are all the error codes that I get on the second scan (when the car won't start):
ECM: not showing at all.
ESP:
C1038 1/2
State: Current
Engine control module not identified or incorrect control module
C1022 2/2
State: Current
CAN communication with the engine system is faulty
IC:
B1102 1/1
State: Current
Fault in CAN communication with control module ME-SFI
SAM_F:
B1036 1/1
State: Current
The input signal'circuit 61'is not o, k
SAM_R:
B1078 1/1
State: Current
Fault in communication with component H3/1(Alarm signal siren with additional battery) or there is a cable fault
TCM:
P2311 1/2
State: Current
One or more messages from the engine control module are not available on the CAN bus, (CAN timeout fault)
P2312 2/2
State: Current
