Cabriolet roof
Old Jul 21, 2020 | 07:40 AM
Ali Blackstock's Avatar
Clk 200 cabriolet
Cabriolet roof
looking for advice.
I have a 2008 clk200 the roof stopped working halfway through the cycle which has locked the trunk is there another way to operate manually or some way to get into the trunk
Old Jul 24, 2020 | 07:02 AM
SwissKiss's Avatar
Black 2004 CLK (w209) 320 Cabrio auto transm. "Elegance" trim; <br /> 2014 A180 black man.
Originally Posted by Ali Blackstock
looking for advice.
Happened to me. After a while, hydraulic pressure will drop, and so will the top (just be careful not to have anything like a finger or a wrist inside the mechanism). You can fold it back into the trunk (the easiest). You can then close the trunk with some muscle power to allow unlocking it normally. Then you can start troubleshooting.
Start with the yellow relays located by the hydraulic pump hidden on the left side of the boot. You can check out my post:
https://mbworld.org/forums/clk-class...em-solved.html
Old Jul 25, 2020 | 09:56 AM
OR-CLK350's Avatar
CLK350 2007
Same thing here. If you don’t hear the pump whirring, the two solenoids are the most likely culprit. Most MBZ dealers have them in stock and are not expensive.
Old Jul 25, 2020 | 03:40 PM
Jojo529's Avatar
2005 CLK320 Cabriolet
There’s a ton of videos on YouTube showing how to do this
