Gear Selector Swap - anything to be aware of?
Old Aug 11, 2020 | 06:25 AM
breeze247's Avatar
W209 CLK55 - 2003
I'm about to replace the gear selector after reading a fairly standard set of error codes. Car is a 2003 CLK55.
I can see that I need to pull the center console and remove 3 bolts and a set of connectors inside the car. I understand that there is a gear linkage underneath the shifter that needs to be disconnected as well.
Two areas that I'd welcome views on:
- Is there anything specific I need to do underneath the car to detach the gear linkage? Do I need to remove any heat shields or is there a way to do it inside the car?
- Are there any areas that I might get caught out on with the lower center console removal? My car has a blower motor under the arm rest.
Hoping this is fairly straightforward, but don't want to be left with a car that can't move whilst I wait for parts or anything else.
Old Aug 11, 2020 | 01:58 PM
dzmitry's Avatar
2023 E450 AT, 1996 S420, (sold) 2004 CLK320 Convertible (v8, 6 speed)
There is nothing to disconnect from under the car. I'm not 100% sure, but I think you can remove the shifter even without remove center console.
Old Aug 11, 2020 | 03:58 PM
breeze247's Avatar
W209 CLK55 - 2003
That would be great. Workshop instructions suggest you need to remove the console, but it looks like it could be edged out with a squeeze.
Are you sure there are no clips? The video that I found suggests there is one that can only be done from below.
Old Aug 11, 2020 | 04:38 PM
dzmitry's Avatar
Link
There is a "clip" or more C-clamp you need to remove in order to disconnect the shifter linkage, but to access it you simple need to lift the shifter and you'll have it. That is how I did it, but I removed the center console, maybe without removing it you won't have enough space to lift the shifter.
