Fog lights flash
What you have may be ok. Did you check for load resistors on them and if they are ok. I am not sure what the resistance reading should be (probably 50-100 ohms).
If you replace them, i suggest going to an OE distributor like Pelican, id the OE, see if they carry a LED replacement, if so get it. If not copy pic of OE and try to find LED ones that have the exact connect taps and location.
