front turn signal problems
Old Sep 5, 2020 | 12:43 PM
CLKAMG500's Avatar
2005 clk500 amg
OK. so i am still learning alot about this 500. but i ran into a problem . i went for a brake light inspection on the car and was told that the front turn signals do not work. i decided to check out the head lamp assembly and noticed that the connector thats for the blinkers, do not have a plug in wiring like the low beams, high beams and parking lights. i googled online as well but when they replace the bulb, it also shows that its just a "turn in, turn out" application. with that said, im assuming that the connection points to trigger the light to work are within the housing since it doesnt require plug in wiring. so im curious as the lights are not blinking at all? side mirrors work just fine. Is there an plug that plugs into the headlight housing somewhere that i may not not plugged in? The bulbs look fine. the filaments are in tack.
Old Jan 23, 2025 | 10:43 AM
zahs's Avatar
Passenger side front turn signal doesnt work, side mirror and rear works fine
Hi, I have similar issue noticed there is no plug or connection to turn signals, just the twist action. I tried to use the other side turn signal housing it still doesnt work. If you find the solution please let us know. However tread is fairly old and no one responded yet. CLK320 A209 2004 Australian model
