beep beep coming from heater ac control fascia
CLK500 Convertible
Hi all, i went to start my car the other day and noticed the battery was a little flat, i charged the battery and noticed a quiet beep beep 8 sec delay beep beep - this does not change if the car is on or off. Its coming from the heater ac fascia. I have a carsoft scan tool and the only thing i found was a fault code b1590, component a32m2 activated charcoal filter flap motor is stiff or blocked. I can confirm the motor is working as i can see this from the engine bay, when i receive the datastream the motor is being told what position to go to but the current position of actuator motor does not change, i have reset fault but this has not helped. Not sure if this has anything to do with the beep beep.
CLK500 CAB
2003
CLK500 CAB
2003
.I thought that the 2003 CLK Cab was still the W208/ You may try posting in that forum.
CLK500 Convertible
I have found the problem, after digging around after removing head unit there was a steering wheel module for the sony head unit that was making the noise, i removed and reset and the trouble went away, thanks for anyone that tried to help. Now all i need to know is if i need to pull dash out to replace component a32m2 activated charcoal filter flap motor, or can this be achieved without removing dash.
