2003 CLK320 transmission not engaging
2003 CLK 320
My '03 CLK320 just stopped driving today and won't move in any direction. The system will lock the wheels in Park and release them in Neutral. The engine is running fine and engine revs up but no movement when the gear shifter is on Drive. It was a heavy raid day and I'm hoping a sensor or something like that got wet causing the failure. I will know if that is the case once it's dry and I try it out.
Either way I would like to know if anybody has any idea what could cause this to happen? If it is a sensor I need to get it repaired as I need the car to get to work.
