loud noise from engine
Old Jan 5, 2021 | 01:53 PM
mylona78's Avatar
clk200 w209 2004 kompressor
when i start my engine i hear a loud grinding noise .i hear it all the time it dosent matter if its cold or hot. steering funconality its ok. when i put a screwdriver tomy ear it feels like maybe the bearings are goine bad with the power steering pump. even if i put my hand i feelf vibration .i change my steering fluid it was brown and smelly burned.any ideas please
Old Jan 6, 2021 | 09:53 AM
zill's Avatar
2008 CLK 550 2012 C300
Hey Mylona,
ill let the forum members tell me I’m nuts.....
if you think the power steering pump is shot remove the serpentine belt start the cold car briefly to see if the noise is eliminated by isolating the pump.
zill.
Old Jan 6, 2021 | 10:29 AM
mylona78's Avatar
hi,welll i took off the belt so i started the engine without the belt .The engine sound is good ialso checked all pulleys all of them good and no funny sounds exept the power steering pump.
The ps pulley is wobbling side by side but the hydrolic steering wheel is working ok is working ok ,
when i install the belt the pulley does not wobble but making loud noises.
is it safe to drive until it gets fixed???
can i rebuilt the pump with the internal bearing or is it shot?
Old Jan 6, 2021 | 11:30 AM
zill's Avatar
Mylona,
ok we got more information.
replace the pump with new. Not sure if you can even rebuild these. New runs from $90-400. While you got it torn down might also replace the filed reservoir. The reservoir O ring and ring groove tend to wear out.
not such a hard job. Enjoy.
Zill.
Old Jan 6, 2021 | 11:33 AM
zill's Avatar
Safe to drive? I would not like to think of the pump shedding fragments and that getting into the rack. Soon as you get a break. Reserve 2 hours, set up and repair.
Old Jan 6, 2021 | 11:38 AM
mylona78's Avatar
Thank you for your time
Old Jan 6, 2021 | 11:53 AM
zill's Avatar
No biggie.
Let us know how it turns out. Maybe replace the belt as well since you'll remove that at the same time.
Old Jan 8, 2021 | 11:39 AM
mylona78's Avatar
Hello all wellis turns out it was the power steering i replaced that .but i do hear not the pump but somewhere right of the pulleys a noise its like a ticking but i cannot determine where or what
Old Jan 8, 2021 | 12:34 PM
zill's Avatar
Hey,
The ticking you hear could be the fuel vapor carbon canister valve pulsing open and closed. It usually happens around start up. Someone else in the forum could come back and say that carbon trap was removed years ago. But I got one on the left hand side of the engine compartment. Same side as the PS pump.
See what you've done? You made your engine purr nice and quiet. Now you hear other things in the night.
Zill.
Old Jan 9, 2021 | 01:22 AM
mylona78's Avatar
i will check it and report back thanks
Old Jan 9, 2021 | 01:23 AM
mylona78's Avatar
and allso with the noise the sepertine belt moves side by side when it moves to one side i notices it makes that sound
Old Jan 11, 2021 | 12:23 PM
zill's Avatar
Mylona,
since the belt is ribbed and travels in corresponding grooves on the pulleys that do work I doubt these are sliding back and forth. More than likely it’s either an idler pulley or the belt tensioner. Those bearings can fail. The description you provided regarding the belt noise and location makes me think the tensioner is shot.
Old Jan 11, 2021 | 01:48 PM
mylona78's Avatar
i will get back to you onthis. i dont know when because we have a lockdown .
Old Jan 12, 2021 | 09:06 AM
zill's Avatar
Mylona,
lockdown, eh. You guys take care. Tell you what, I’d rather be in a lockdown on your beautiful island than me being cloistered in my house in the winter in NY.
w.
Old Jan 12, 2021 | 09:01 PM
mylona78's Avatar
Mylona,
w.
Yes you are very correct
