DEAD WIPERS
Old Aug 27, 2021 | 08:51 AM
Shayski's Avatar
CLK350
DEAD WIPERS
Just picked up an 06 CLK 350 and I love it, but being an older car it has come with a few issues. I’ve never owned a M B before so I have no idea where to start to fix these problems. So hopefully somebody can help me here. Well the most pressing issue is that I have no wipers. When I twist the knob on the blinker lever, nothing happens, but if I push the knob in then the wipers will start as long as I keep the lever pushed in. I’m guessing that it’s probably not a fuse issue but more like a bad switch in the steering column that’s connected to the Turn signal lever. Am I on track with my thinking? Ok, now the nextt item on my list is the automatic locks are not working when I use the key fob or push the door lock button on the dash. The lock on the drivers door seems to have a problem going up and down, even when just using the key. Is there a lock motor inside the door that raises and lowers that lock and do those go bad?
