2 message, often together (washer & coolant)
Old Sep 11, 2021 | 05:07 AM
mpiva's Avatar
CLK (A209) 200K Cabrio
Hello,
Introduction
I own a CLK A209 200K (2004), Engine M271.940, with BRC LPG. The car is fantastic.
Unfortnly, the previous owner was a "dog", who did not deserve the car. Now, step by step, I'm going to fix all little problems that I have found.
I have already resolved the knowed problem about oil leakeage from magnet sensors. Now I'm continuosly cleaning connectors and harness (engine indicator light switch on every 2 or 3 days).
But I have this strange problem:
On the command appears the message "Coolant Check Level". Immidiatly or after few seconds (less than a minute) appears "Washer fluid check level".
I open the coolant resvoir tank, I see liquid, actually it seems low --> I think the leakage is on the tank, I see wet surface at the bottom of the tank.
But the washer tank is full! but the "strange thing" is that these two messages appear together. Are they related?
So, someone of you have had similar problem?
