Is CLK500 Flexplate Different Between 2004 and 2005?
Old Jan 5, 2022 | 08:38 PM
HETPE3B's Avatar
Own 2005 CLK500, but drive 2011 Sienna :)
Is the flexplate that it is attached to the torque converter is the same or different between:
2004 CLK500 M113 with 722.6 transmission
2005 CLK500 M113 with 722.9 transmission
Old Jan 6, 2022 | 02:42 PM
HETPE3B's Avatar
The answer is - no difference. Thanks everybody.
Old Jan 7, 2022 | 02:00 PM
dzmitry's Avatar
2023 E450 AT, 1996 S420, (sold) 2004 CLK320 Convertible (v8, 6 speed)
It might not be applicable in you case but just in case there might be a different between, simply because there is a different between early 2004 and later 2004 flex plates (different crankshaft bolt pattern).
I think starting from engine number "31 757522' they changed the bolt pattern.
Old Jan 7, 2022 | 05:37 PM
HETPE3B's Avatar
Got it. I just was concerned at first when I did swap the engine from 05 CLK500 to 04 CLK500, but the transplantation came out ok. However have a CEL with P2004-002 Code. Still need to chase it.
Old Jan 9, 2022 | 12:29 PM
HETPE3B's Avatar
The replacement of MAF sensor fixed the code. One more 2004 CLK500 is back on the road again Will be for sale in a couple months after I'll have some fun with it.
Old Jan 9, 2022 | 02:18 PM
dzmitry's Avatar
Nice!
Old Jan 16, 2022 | 10:56 PM
HETPE3B's Avatar
Got new video
