Fuse chart needed
Old Jun 16, 2022 | 04:50 AM
Kiwibenz's Avatar
2003 E500, 2010 C300
Fuse chart needed
Hi all,
I have a 2003 CLK 320 convertible/cabriolet/soft top.
Unfortunately I have not been able to locate the fuse chart for the vehicle, I have checked the normal location and also checked thru the car in case it was placed somewhere else.
I have tried a search in the forum, and found a thread where someone had posted a link, but that link unfortunately is now not working
My car is a right hand drive vehicle.
Does anyone have knowledge of where I can get one from. My local Mercedes dealership were not any help either!
Cheers,
Graeme
Old Jun 18, 2022 | 03:55 AM
Ward Purcell's Avatar
2003 CLK 320
Hi Graeme,
I have a 2003 CLK 320 but its a coupe, not a convertible.
Happy to have a look if i have the actual diagram in my car but a quick Google search i did find this page. Obviously the physical locations of the different fuse boxes will be reversed for RHD.
https://www.autogenius.info/mercedes...w209-fuse-box/
Let me know if you want me look in my car for the actual diagram - i am in Australia so it should be the same.
Cheers
Ward
Old Sep 27, 2022 | 12:58 AM
Santa_Jay's Avatar
CLK500
If you still need a fuse chart, I can scan and send PDF
If you still need it, I can scan the one for my 2005 CLK500 Cabriolet.
Old Sep 27, 2022 | 10:56 PM
Kiwibenz's Avatar
Thanks for the offer. I went back to the dealership and saw a certain parts guy there, he was able to order one for me, from Germany!
So all sorted now thanks!
Graeme
Old Sep 29, 2022 | 11:07 AM
bracester's Avatar
2007 CLK 350
I have the full service software if you needed something in the future
Old Oct 6, 2022 | 08:47 PM
Bryan3r3's Avatar
CLK500 (W209)
Do you have one for 2005 CLK500 (W209)? Are you able to tell me what causes these codes or how to fix?
ECM: P20CC-008 Rough road detection' signal (by comparing wheel speeds): Speed signal from control module ESP unreasonable / Read out fault memory of control module ESP, (P1999)
ECM: P2036-004 No or incorrect CAN data from control module N47-5(ESP control module) Communication fault / See also CAN state in freeze frame data(P0600)
TCM: P2310 No CAN data was received fromcontrol module N47-5(ESP and BAS control module) (171/203/209) or from control module N47-5(ESP control module) (164/219/ 251/216/221) , or from control
ESM: P1876 The signals sent by control module N47-5(ESP and BAS control module) or N47-5(ESP control module) for the wheel speeds and the braking torque are not available on the CAN bus
ESM: P2012 The brake signal from control module N47-5(ESP and BAS control module) or N47-5(ESP control module) is not available on the CAN bus
Anything I can check for before taking the vehicle to the dealership?
