View Poll Results: Abs issue
Bas fault
0
0%
Esp fault
0
0%
Voters: 0. You may not vote on this poll
Abs esp bas fault
A209 clk 320 convertible, r171 slk350
Abs esp bas fault
Changed all suspension arms on clk 320
now got abs, esp, bas fault on dash
Error code c1110 l6/2 right front speed sensor
changed abs sensor and ring, had abs pump check and repaired!! Still gave fault.
I don't have the heat shield around the disc is that the issue or has anyone got other ideas
You need to get diagnostic scanner that can monitor the pulses from the wheel sensor. Sounds lie you have installed incorrectly, or your scanner is giving bad information. If it is working, then may reset its self after short use. If not then you need to investigate further. The shield should not cause a problem, but there is a seal around the sensor to keep dirt and grit away from reluctor and sensor.
