722.6 CLK500 trans failed, any help with what’s going on? Kind of an emergency
my thoughts
conductor plate
torque converter
I’ve heard these transmissions were really good and I wasn’t racing or anything exhorting a lot of stress just a mere heavy takeoff, surely this wouldn’t kill the torque converter..?
I’ve researched and people say the conductor plate is a common fault, however that piece seems to be purely electrical so in theory it wouldn’t product any whine or clunking when driving or starting the car.
now that I think about it, maybe it’s possible I snapped an axle?
my situation is really unfortunate, dad just got incarcerated, mom needs rides to hospital, I’m 3 hours away in college having to commute, not asking for sympathy just any help! Thank you
Slow down and think through this calmly. The transmissions are not robust enough to surmount being driven when they should have been serviced. When you continue to drive while a car is making those sounds, you ARE damaging something. No free lunch here. If you ever find yourself thinking "I'll just limp it home" - - this is outright code for "I don't care if the engine dies".
Troubleshooting 101 - do not make wild guesses about which part is broken. Start with a methodical process of elimination. Axels on cars do not "snap" unless you have 500hp going through axles that came on a 200hp car and you are doing drag race launches at every stop light.
I can appreciate you are a college student that sounds like they don't know much about cars? If true, this may not be the time to learn in a stress free, economical manner. However, with Mercedes ownership comes the joy of purchasing many specialized tools - NONE more important than the code reader. While Autozone has OBD readers that you can use for free in their parking lot, the engineers at Mercedes designed a Mercedes-specific diagnostics code schematic that can only be read with a Mercedes-Specific reader. I use an iCarsoft MercedesII and it costs about $140 from Amazon.
STEP1 - Pull codes from the OBD2 computer port with the proper code reader. You can try using a generic OBD2 reader to pull codes (write all of them down) as it will at least give you something to diagnose from (Engine V Transmission).
STEP2 - Based o you saying there was a loud clunking noise, it does sound likely the issue is with your transmission. They aren't invincible, but since you didn't provide any information on the miles your vehicle has, how long you've owned it or any maintenance history, I'll assume all maintenance was deferred and you just purchased the car a few weeks ago. IOddly, Mercedes chose not to include a dip stick with these cars to check the fluid level of the transmission, but you can buy one from Amazon for about $10. Generally you check fluid level of a transmission while the vehicle is running, but this might not be possible in your case, so there is a "cold" level indicator.
