Engine Ticking Noise
Old Oct 22, 2004 | 01:52 AM
bj'sbrabus's Avatar
CLK 500 Brabus
I purchased my first Mercedes last week, a CLK 500 Brabus. I love the car and the styling but.......When I started the car the first morning, I noticed a ticking noise that sounded like a hydraulic lifter was not filling properly. It occurs with each engine revolution and is especially apparent under any degree of acceleration. I took the car in to the dealer for resolution and after keeping it overnight to do a cold start, they proclaimed the sound normal. Finding it hard to believe, I test drove another new CLK 500 and to my surprise, the same ticking noise was evident. I then drove a CLK 55 AMG and no noise was apparent. The rental car they gave me (430 I think) did not exhibit any noise. Has anyone else experienced this problem and been given a more comprehensive explanation than "normal".
I have looked through tech bulletins and service letters to no avail. Only similar noise was the exhaust manifold air compressor or altenator.
It seems to be getting louder and I am very uncomfortable fearing it might be a valve or rod bearing.
Old Oct 22, 2004 | 03:21 AM
JLee81's Avatar
04 CLK55, IWC CLS55 AMG(one of 55), 07 Honda CR-V 4WD
did you ever hit a puddle hard enough to splash the water higher than your car? I am pretty sure that you did, if you are hearing the noise(only when the engine is cold- goes away and comes back while driving) even though you don't remember it now.
I had that ticking nose that sounded like it's coming from the engine when I had W203 C320 about 1 1/2 year ago. It definitely ticks during low engine temperature.
Guess what! the water got in the engine room and it ****ed up the car pretty badly..
Well, I traded the car and got my clk and I don't have to live with it anymore.
Good luck and hopefully it's not as serious as the problem I had with C320.
Old Oct 22, 2004 | 03:47 AM
MikeL's Avatar
Uber 202
There's a **** load of TSB's and a few recalls for MY 03 CLK500. You can check www.alldata.com for all makes and models. Recalls and TSBs. Ill list a couple TSB's that could be your problem of a ticking noise.
TSB's
S-01_30-15 Engine - cylinder wall damage assesment
P-07_00-21F Engine - piston slap sound on acceleration
These could be it? Below is a copy and paste of all recalls/TSB's for MY 03 CLK500. Hope this helps.
Bulletins for 2003 Mercedes Benz CLK 500 (209.375) V8-4966cc 5.0L SOHC (113.968)
Safety Recalls
TSB Number Issue Date TSB Title
1. 2003120006 JAN 04 Recall - Seat Belt Buckle Replacement
General Recalls
1. 2003110006 APR 04 Campaign - Engine Cooling Fan Malfunction
Service Bulletins
1. P-46_20-16 APR 04 Steering - Leaks at Line/Rack Housing Connection
2. S-07_61-039A MAR 04 Engine Controls - DTC Trouble Shooting
3. P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
4. P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
5. P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
6. P-33_15-10 FEB 04 Steering/Suspension - Alignment Requirements
7. P-82_00-228B FEB 04 Audio System - Mutes Randomly
8. S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
9. S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
10. P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
11. P-54_65-104A JAN 04 Parking Assist System - Triggers for No Reason
12. P-47_10-27 JAN 04 Fuel System - Fuel Filler Cap Hard to Remove/Install
13. P-20_40-26 DEC 03 Engine Controls - Cooling Fan Runs Continuously/DTC's
14. P-82_30-316 DEC 03 Wipers/Washers - Erratic Intermittent Wipe Explanation
15. S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
16. P-82_30-279B NOV 03 Wipers/Washers- Poor Wiper Performance
17. S-54_21-101 OCT 03 Engine Controls - ECM Flash Process Change
18. P-82_60-292 SEP 03 Audio System - Volume Knob Damaged
19. P-62_00-06 SEP 03 Body - Water Leaks Into Front Footwells
20. P-82_85-288 SEP 03 COMAND(R) System - Unable to Enter New Destination
21. P-54_18-98 SEP 03 Battery - Disconnecting Requirements During Vehicle Svc.
22. P-80_57-24 SEP 03 Drive Authorization System (DAS) - Component Diagnosis
23. P-18_00-22 AUG 03 Engine - Oil Fill Capacity Correction
24. P-07_07-34 JUL 03 Engine Controls - MIL ON/Multiple DTC's Set
25. P-82_85-264 JUL 03 Navigation System - Inoperative/Erroneous Guidance
26. P-07_00-21F JUL 03 Engine - Piston Slap Sound on Acceleration
27. P-14_30-15 JUL 03 Emissions - MIL ON/DTC P2003 Stored in Memory
28. P-54_30-87 MAY 03 Instruments - Clock Inaccurate
29. P-20_10-23 MAY 03 Cooling System - Water Pump Leakage
30. P-54_65-86 APR 03 Parking Assist System - Apparent Erroneous Activation
31. P-42_45-23E MAR 03 ABS/Traction Control - DTC's C1140/C1145
32. P-82_70-222 MAR 03 Cell Phone - Phone Won't Fasten Into Cradle Holder
33. P-67_00-09 MAR 03 Body - Windshield/Rear Glass Body Seam Corrosion
34. P-54_18-84 MAR 03 Battery - Disconnecting During Service
35. S-07_61-27A MAR 03 Engine Controls - ECM Reprogramming Procedure
36. P-80_57-20 FEB 03 Audio System - RF Interference Explanation
37. P-46_20-10 FEB 03 Steering Rack - Connector Leaks
38. P-82_10-217 JAN 03 Lighting - Parking/Tail Lamp Bulbs Inoperative
39. P-82_85-210 NOV 02 Navigation/GPS System - Various Malfunctions
40. P-82_30-209 NOV 02 Wipers/Washers - Wiper Blades Noisy
41. P-77_20-18 OCT 02 Body - Sliding Pop-Up Roof Reverses When Closing
42. P-82_62-169B OCT 02 Audio System - Various CD Player Malfunctions
43. P-72_10-28 OCT 02 Power Locks - Lock Knob Jumps Up and Down
44. S-82_70-135B OCT 02 Fiber Optics System - Configuration/Version Coding
45. P-18_00-17A JUL 02 Engine - Approved Engine Oils
46. P-82_85-198 JUL 02 COMAND(R) System - No Sound/Whistling
47. S-07_08-001 JUL 02 Engine Controls - Software Calibration Number Coding
Old Oct 22, 2004 | 06:49 PM
bj'sbrabus's Avatar
CLK 500 Brabus
Mike,
Thanks a million. That web site is more comprehensive and easier to use than the site I looked up. The piston slapping bulletin seems to fit better but it does not show up for the 2004 model. I will call the service adviser and ask him to look up the TSB number. Maybe they will take me more serious.
Brad
Old Oct 29, 2004 | 12:29 AM
bj'sbrabus's Avatar
CLK 500 Brabus
Problem Solved
Turns out the problem is an issue with front engine mounts on some of the CLK 500's that will cause a ticking noise that sounds like "piston slapping". The dealer replaced the front engine mounts and problem is completely solved. Thanks to Mike L for the TS information.
Old Oct 29, 2004 | 12:19 PM
jyg e500 maybe's Avatar
2000 528BMW 5sp
what year is your car.?
wht year. I thought motor mount problem was fiixed and was only on e-class v-8
Old Oct 30, 2004 | 12:21 AM
bj'sbrabus's Avatar
CLK 500 Brabus
The car is a 2004 CLK 500 Brabus purchased new just 3 weeks ago. It appears the service bulletin was originally issued on the 2003 but the mounts were revised again with a different type of rubber, according to the service rep.
