Driver low beam non-op (bi-xenon / HID)
Old Mar 28, 2023 | 08:59 PM
Diamond Dave's Avatar
GL320 CDI
So, I've replaced the bulb, removed the headlight and plugged it into the passenger side, replaced the ballast with a new one and checked the fuse, but the low beam does not come on.
In doing research, it sounds like the igniter is also a common issue, however, my lights have the newer style igniter that is mounted inside the headlight, so instead of just cutting the wires and connecting a new one, I'd need to open the lens to remove it and replace it.
Based on research, it seems like my only option to replace the igniter is to open the lens?
Here is the style igniter my CLK uses: https://www.partsgeek.com/lcg47gh-me...hoCUjEQAvD_BwE
