Noisy component on belt way
Hello from France with desperate research of this fu... Acute noise. 192000km year 2004.
https://we.tl/t-Fr1wacazlP
All parts on belt way have been replaced except a/c compressor and alternator (only the freewheel pulley). Noise desappears with belt out. Several garage told me it's kompressor. Removed mine, ordered younger one on benzshop.de, replaced the oil and problem stills. Can be this second kompressor damaged too ? To be honest it's big labour to remove third time this kompressor and part around and I would like to share with you on this point.
SPONSOR
11 E550, 16 AMG GTS, 13 S550
Alternator. theres a play in the pulley in the video which was my first suspicion. The whirring sound similar to a supercharger that you can hear from inside the car is my second clue. The third clue is when you zoom in on the power steering reservoir and the sound is very pronounced and I see brand new idlers, power steering pump, and it isolates the issue away from the AC compressor.. The only way you can prove it further is by unplugging the alternator which is next to impossible. I hope this helps.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Service Manager/Owner
Amsoil Independent Dealer #7236674
Thank you for your help. Indeed the steering pump is new. When I turned by hand it was very noisy but that doesn't change anything with the new one. The problem when you remove the belt is to be able to rotate each element separately to test it but it is impossible.
SPONSOR
hopefully you resolve your issue and we were correct
__________________
Yes for me from the begining the noise comes from the left side (face to the motor.
So, after the steering pump, stills the alternator.
I'll remove it and check.
Thx guy.
Thx guy.
