Windscreen washer failed
New CLK owner here W209 2005.
I've a question re the washer pump. Are there two or one? I.e. one for the headlight washer and one for the windscreen?
the reason I ask is the headlight washer works fine, blasting out water but the windscreen washer is not working.
when I press the windscreen wash there's nothing, no pump noise etc so it feels like the pump motor has failed but I'm confused as the headlight one is working!!
any help or advice gratefully received.
When I got my '03 W209 I had the opposite. Windscreen washer worked fine but previous owner said the headlight washer had never worked. He'd had it since 2006
Couldn't have that. Easy change. Both pumps are located under the front of the arch liner on the left hand side of the car. Mine's a rhd car but I believe location is the same.
