How to disable/remove Tele Aid Altogether
Mercedes doesn't even have any telematic access to this vehicle. Only model years 2013 and newer. How can I rid myself of this module? The cluster doesn't even acknowledge when the is inserted. I can't turn the key to any position. Any help would be much appreciated. I have the scanning and key programming tool: Autel SysMaxis IM608Pro with XP400 key programmer, G Box, and JCI communication box. This as far as it will let me go because the key needs to be in the on position in order to communicate with ECU. Unless there is a way I can jump power to the ecu to conduct a full scan?
