Transmission issues
Old Nov 26, 2023 | 03:50 PM
Railton's Avatar
CLK 240 cabriolet
Exclamation Transmission issues
Good Evening all.
I'm at a loss... can anyone help me? Please.
2004 CLK240 (722.6 Transmission)
I have bought a project car that starts and runs beautifully but will not go into gear.
Select R or D and no go!
Select N and give some throttle and it will slowly move forward,
I have replaced the connector on the Transmission and drained / replaced the transmission oil.
Today I replaced the valve body, conductor plate and solenoids.
Still no GO!
What next???
Any help will be greatly appreciated.
Old Nov 30, 2023 | 10:04 AM
Lazarev8ch's Avatar
2006 CLK 320 CDI AMG
Did you reset the codes ? If they're still in memory they could prevent you from doing anything.
Old Dec 3, 2023 | 05:16 AM
Railton's Avatar
CLK 240 cabriolet
transmission issues
Hi,
I had one code (P2004) which I cleared with a "Carly" OBD tool. there are no other coeds at all.
Old Dec 3, 2023 | 05:58 AM
Lazarev8ch's Avatar
Considering you replaced the valve body/conductor plate/solenoids, were they coded to your car ?
If you did, you might just need an adaptations reset. There are tutorials on how to do it with the pedals, but if you want to be more thorough, do it through your diagnostic tool.
