SRS Error Code 9243 - How to disconnect the Squib
I've borrowed the attached photo with the "A" and "B" written on it showing the underside of a 350 CLK front passenger seat from the following thread: https://mbworld.org/forums/clk-class...9243-help.html Can anyone use this as a reference to tell me which cable I should be disconnecting and how? Or do I need to remove and reconnect the plate with the yellow plugs seen in the lower right hand corner in the labeled photo and also in the second unlabeled photo? (I ask because I saw that in one video fix but they did not say it was the squib.)
A few related questions: Do I need to disconnect the battery before manipulating the squib? If the code shows "stored" vs "active" will it resolve with enough key starts the way (some) other codes do? I tried to clear the code with the Innova app which was not successful. Just surprised that the code doesn't show as active if the problem is still present.
Thanks in advance!
Kodi
