722.6 transmission issues
Old Feb 7, 2024 | 05:53 AM
FlashJJH's Avatar
CLK 500
Hello, I recently purchased a 2003 CLK 500 because it was under 30k miles and the car looked sweet. The problem is the transmission likes to hang, make noise and jerks a lot at certain throttle inputs when it’s trying to shift up or down. Yesterday was my second day owing the car and the car was hanging at very high rpm when I was driving around 35 mph so I had to go into neutral. The issues usually smoothes itself out when I either let off or add more gas, but what would be the most likely culprit for this issue? I have little to no mechanical experience so any help is greatly appreciated!
Old Feb 8, 2024 | 03:58 AM
rich1068's Avatar
W209 CLK 240
Get it booked in for a transmission fluid change/service. I'm guessing that regardless of the car being 20 years old at 30k miles it won't have been done. Full kit is something like this. Plus an hour or two labour.
Old Feb 9, 2024 | 07:58 AM
JD-CLK's Avatar
2004 CLK500, 2007 CLK550
30K miles on a 22 year old car? That thing has been sitting, you probably are low on transmission fluid. Bad/Leaky seals
