Just pulled the car out for the season and this happened when I tried to close the top, the tonneau gets this far and the pump motor will continue to run for several seconds then the pump motor stops with a notice on the dash that the top is open. I gently pushed the tonneau down and then opened the top without issue, I then closed the top and it worked as it should..... until I opened the top again and then the tonneau would not complete the cycle as seen below. The car is a 2005 CLK 320 with 9,000 miles.
Is this an easy fix or something I should take to a pro?
