Hello everyone. I used my top a few times so far and when I went to use it last. It will roll down the window and do nothing else. The message that says top is in operation would go away after 5 seconds. No error. I pulled the codes and for B1928 and B1923 through carsoft ii. I changed out both sensors and erased the codes and when I went to try it I got the same codes and same results. I read all the fourms and did research and I am stumped by this. I would appreciate any help.
The last time I closed the top it made like a big thump when it closed . That's the only weird thing. But I have opened the top manually and everything moves free.
