Should I add fluid to my dry battery H7
I know how to test a battery for Cranking amps. The question was and remains. What do you do when you open the caps to these type of Mercedes batteries and they look dry inside
So my first thing to do was say OK well, maybe she’s just a little dry how these batteries work are they a gel bat which I knew they’re not because those are very expensive
So I figured there it’s dead and not charging up because it’s dry. Back in the day whenever we saw a battery that was low we would just add some distilled water to it and run the car for about 15 minutes and you’d be good to go. It was a lot better than it was.
